Ox
- Aug 27, 2002
- Northwest Ohio
Looking at trying to hold a 1mm shank, and fit down inside an 8mm hole a little ways.
Ox
Ox
Ox,
Use drill rod (silver steel called here) which is ground round great size and straight.
Drill in the end and loctite 603 the cutter in.
It'll work like a charm, and if you break the cutter and have to swap it out, use a little heat and the loctite will 'break' and the cutte rwill pull out with pliers.
Can you just use a 1mm carbide em with a 6mm shank? Try Micro 100.
That has 1/4" capacity too.
Shirley way too big to fit in there.
I didn't know Harvey had collet holders. Hmph!
(Guess I need to look through the catt better?)
Thanks anyhow....
Ox
Notice
