Thread milling with boring bar
Results 1 to 9 of 9
    Mar 2007
    Aylesbury, U.K.
    232
    11
    Question Thread milling with boring bar
    We were talking with a very experienced CNC machinist and he suggested using a lathe boring bar with a thread cutting insert to mill threads with our Haas VF0. Much cheaper than purpose made thread milling tools.
    Will this work OK? Anybody else doing this? Our visitor was absolutely confident that it would work.
    Regards,
    Mike.
    Jul 2004
    Spartanburg, South Carolina
    1,534
    48
    97
    It works, but it's slow.
    Oct 2005
    England
    3,021
    24
    685
    Can be done
    But its slow, but if you've got no other way of getting a thread in there... or its a one off part with a very odd thread.
    Heres an example program for a 20mm*2 thread 40 mm deep
    Have not put in any roughing cuts or anything
    O1001
    T1 S1500 M6
    G54 G0 X0 Y0
    G43 Z0 H1 M3 // tool height
    G1 G41 Y20 H21 F250 // move to tool out to thread dia with comp
    M98 P201002 // call the threading 20 times
    G1 G40 Y0 // cancel comp
    G0 Z25 M5
    M30
    O1002
    G2 J-20. Z-2. // spin the tool around once and down the thread pitch
    M99
    Boris
    May 2005
    Out in the middle of nowhere
    244
    Oh yea, do it all the time
    Gary
    Jun 2006
    Thunder Bay Canada
    1,731
    478
    265
    Default THread milling with BB
    Quote Originally Posted by mrainey View Post
    I did 4" of 2.75-12 thread in mild steel using a HSS tool and boring bar. Feed was 0.3ipm (BB centerline). Set up a subroutine (as above) and went for coffee. Perfect thread, but the tool has to survive for the whole process if its not an indexable insert.
    Dec 2006
    Central Ky
    1,062
    51
    78
    If you guys are familiar with the triangle shaped thread inserts (for lathe IIRC), they have three cutting edges, you can mill a triangle pocket on the end of a piece of 3/4 rod, tap a hole and go. Very cheap, and you have three edges instead of one.
    Mar 2007
    Aylesbury, U.K.
    232
    11
    Thanks guys for your advice; I guess that this technique is best for those one off or last minute jobs when buying the proper tool is not an option.
    Regards,
    Mike.
    Nov 2006
    NC PA
    17
    You can also make multiple start threads if you use your scaling and rotation..... KJC
    Oct 2005
    England
    3,021
    24
    685
    Quote Originally Posted by crowellmachine View Post
    Eh?
    Not meaning to pour cold water on your idea but for a M40*2 2 start thread like the single start listed above:
    O1001
    T1 S1500 M6
    G54 G0 X0 Y0
    M98 P101002 // call the threading 10 times
    G0 Z+2
    G1 G41 Y20 H21 F250
    M98 P101002
    G1 G40 Y0
    G0 Z25 M5
    M30
    O1002
    G2 J-20. Z-4. // spin the tool around once and down the thread pitch*number of starts
    M99
    Boris
    And hope the tool does'nt break
