Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > CNC Machining
CNC Machining Discuss CNC machines, programing, troubleshooting, retrofits.
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 06-03-2010, 09:45 PM
mroy0404's Avatar
Default Thread milling on a CNC lathe
Hi Guys
Im setting up a Doosan 2000sy with a Fanuc 18i-TB control. The part beening machined has a cross hole which has a 9/16-18 thread in it. The problem Im having is how dose G41 work?? I need to be able to offset the threadmill in Z and Y axis bit by bit to maintain thread Dia. size. Here is the threadmill part of the program. I not sure where to place wear offset numers as needed.
Thanks for all an any help guys
(THREAD MILL)
(TOOL-11 OFFSET-11)
G54
T1111
G19G98
M7
G0X1.Z-1.1875
G97S2000M33
X.37
G3X.3838Y.0392Z-1.1483R.0392F5.
G41X.3978Y0.Z-1.109R.0392
X.4256Y-.0785Z-1.1875R.0785
X.4534Y0.Z-1.266R.0785
X.481Y.0785Z-1.1875R.0785
X.5088Y0.Z-1.109R.0785
X.5226Y-.0393Z-1.1483R.0393
X.5364Y0.Z-1.1875R.0393
G1X.37
G3X.3838Y.0405Z-1.147R.0405F5.
X.3978Y0.Z-1.1065R.0405
X.4256Y-.081Z-1.1875R.081
X.4534Y0.Z-1.2685R.081
X.481Y.081Z-1.1875R.081
X.5088Y0.Z-1.1065R.081
X.5226Y-.0405Z-1.147R.0405
X.5364Y0.Z-1.1875R.0405
G0X1.
M35
G40
M09
M90
G28Y0.
G28U0.
T1100
M01
  #2 (permalink)
Old 06-04-2010, 02:59 AM
Hot Rolled
The wear you can use in the R in wear offset table.
Input +.003(example) to make the mill virtual bigger, thus the hole smaller(-.006), input -.003 to make the mill virtual smaller, thus getting a bigger hole (+.006).
  #3 (permalink)
Old 06-04-2010, 05:44 AM
Ox's Avatar
Ox Ox is offline
Also - you will need to choose "9" in the rad type column too clear to the right side of the offsets.
Think Snow Eh!
Ox
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
