Just moved to a new shop. Power is a sub panel. Three phase with neutral wires. The metered main panel is not near the unit. Hooking up a panel that will have three phase only. Can I run it off the sub in the unit.? I assume the ground wire grounds to the metal box not the neutral connection at my units panel ? Thanks
