Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Like Tree9Likes
Thread: Tight Tolerance 0.0629-0.0630" hole in Titanium
  1. #21
    dksoba is offline Aluminum
    Apr 2011
    San Diego
    188
    Quote Originally Posted by vettepicking View Post
    What machine shop doesnt have a lathe??? i have 3 (two at my house) c'mon now. how do you make fixtures? Your holding .0001" in a shop with no manual machines. do you have a sign that says "NO SHAFT WORK DONE HERE" ..
    LOL. I should put one up. I do everything on my sloppy Fadal VMC. Usually my prints are +/-0.005" or +/-0.010". When I took this job on, I was told I could do 0.0628-0.0629" w/a reamer. Apparently, I can't.
    I just got word from my friend that he'll take care of the hole diameter, I just need to drill an 0.0625" hole. .... I wish I would've known sooner!
    Matt
  2. #22
    oceanpout is offline Aluminum
    May 2006
    Brockton Ma
    83
    Next time just ask the Engineer if he would like it on the high or the low off the Tol. !
  3. #23
    IronReb is offline Hot Rolled
    May 2011
    Shreveport/Louisiana USA
    692
    Quote Originally Posted by oceanpout View Post
    Better yet,explain to the engineers boss that for every tenth of tolerance they open up the price goes down by a factor of 10
  4. #24
    Radar987 is offline Aluminum
    Dec 2011
    Colorado
    217
    Quote Originally Posted by dksoba View Post
    Matt
    Out of curiosity, what does the print state for tolerance on the hole position?
  5. #25
    Apr 2011
    San Diego
    188
    Quote Originally Posted by Radar987 View Post
    Print states 0.005" regardless of feature size, total tolerance. The hole is referenced to the side of the part (where the datum is).
    Update:
    The shop that subcontracted the work to me said it's my responsibility to get the hole size correct (probably since they weren't able to hold the tolerance on that hole on their sister parts). I did what Steve said to do in post 14 (Tight Tolerance 0.0629-0.0630" hole in Titanium). Steve: I owe you a beer, lunch, or something!
    My exact procedure:
    1. Learn to use my CNC mill (Fadal 4020) as a lathe. This worked out great, but it did take some getting used to.
    2. Turn down aluminum rod (1/2"), since I wasn't having any luck with 1/8" brass and I didn't have any other barstock around, to 0.045".
    3. Pinch end of the rod in the vise, until just over 0.0630".
    4. Using a micrometer, measure the end, and use 1000 grit sandpaper to get the aluminum rod down to .0627-0.0629". (Now it's called a lap).
    5. Use my mill to push/pull the lap down/up for 10 cycles, at 1000 rpm, and a feedrate of 10 ipm. I just guessed at those numbers. Before this operation, the hole was coated with a mixture of Dico premium buffing compound and Rapid Tap cutting fluid. I put it in a syringe and filled the hole.
    6. Clean the hole using isopropyl alcohol injected from a syringe.
    7. Evaporate/blow out any left over isopropyl alcohol using compressed air.
    8. Inspect hole using gage pin. If still too small, go back to step 3. Repeat 3-8 until hole is in tolerance. It took about 6-8 cycles to get it in tolerance. The material is expensive and takes a long time to get, I don't have any spares, so I don't mind that it takes 6-8 cycles. It takes about 30-45 mins to get the hole to the right diameter.
    I noticed that my lap kept getting smaller after each cycle. I'm wondering if a brass lap would work better?
    Steve: where do you get diamond lapping compound (#10)?
    Thanks for everyone's help!
    Matt
  6. #26
    scadvice's Avatar
    scadvice is offline Stainless
    Jan 2009
    "Stuck in Lodi", Ca
    1,017
    Default Great,
    I'm glad it worked out for you Matt. The last time I got it was at McMaster Carr. However, I've had syringes for a few different grits for years. Yaaa...blind hole laps do wear fast, even brass ones. Next time I'm in San Diego I'll get that lunch and beer from you!
    Steve
