WayneC369
Hot Rolled
- Jan 4, 2014
- ATL, GA, USA
Hello All,
I have an Okuma & Howa ACT-20 that I have been learning the ropes on and I have been met with yet another stumbling block: The Tool Counter and it's expected functioning. The MTB manual isn't much help other than it suggests this counter will stop the machine once it's seen the preset number of pulses via the M90 code. Well, all I get is the alarm buzzer and the lathe continues to cycle. There is also an amber revolving light mounted on top of the console that just sits there. I would've assumed it would light up when the buzzer sounds, but no - it doesn't.
Can you tell me what I'm missing? Should I have another M or G code in the program to stop the lathe once the preset has been met?
Below is how I'm either wrapping up the program or looping back. I'm currently presetting the counter to one less than the desired number of parts, once I get the alarm I turn off the Block Skip and allow the program to terminate.
(TOOL #11 CUTOFF )
N90 G28 U0. W0. <<<<< Note: When my balls drop I plan to do tool changes closer to the spindle.
G97 S1500 T1111 M04 M08
G00 X.6724 Z-.6023
G01 X-.02 F.003
G00 X1. M09
G00 G28 U0. W0.
M90 <<<<<< Here is where I expected the machine to stop once the Tool Counter hits the preset value.
(THIRD PULL)
(TOOL #8 BAR PULLER)
N100 M05
G28 U0. W0.
G98 T0808
G00 Z-.875
X2.
M19
G01 X0. F100. M34
M11 (OPEN CHUCK)
W.6223
M10 (CLOSE CHUCK)
X2. M35
G99
/G00 G28 U0. W0.
/M30
M99 P20
(TOOL #11 CUTOFF )
G00 X.6724 Z-.6023
G01 X-.02 F.003
G00 X1. M09
G00 G28 U0. W0.
(THIRD PULL)
N100 M05
G28 U0. W0.
G98 T0808
G00 Z-.875
X2.
M19
G01 X0. F100. M34
M11 (OPEN CHUCK)
W.6223
M10 (CLOSE CHUCK)
X2. M35
G99
/G00 G28 U0. W0.
/M30
M99 P20
