Hello all,
I just want to say I ve been a luker for some time because this is such a great source information for all machining topics related. Today I encounter some doubts and I want to know what you guys think.
I am trying to define some tool life average or type of standard for our workshop (all 5 axis milling machines).
I just want to know you guys what do you think.
I want to divide tool usage by 2 categories:
In our process there are some holes 0.172 +- 0.001 with a Positional tolerance of 0.001 that is shared by 90% of references, the process of this hole is all the same in all the references.
SPOT DRILL----DRILL----REAMER
Part material is aluminum 7075 T5451.
the current material for the hole process is HSS.
Other 2 main processes which are finishing and roughing done by Carbide cutting tools with 3 flutes.
So I plan to change everything to carbide to calculate just a rough approximation to reality.
Once everything is changing I will measure with a software the total cutting time of the tool provided by all the references. Then I will define the time to change the tool, so the operator knows when is time to change it.
The previous time will be an estimate usage of the tools reported by the operators or by the manufacturer.
I dont know what you guys think of this process, any comments will be appreciated.
- Hole making
- Roughing and finishing.
