bdrmachine
- Mar 21, 2017
After many years machining with a manual Lathe I finally purchased a used Romi C420 with a Siemens 802D control. So far (climbing the steep learning curve of a new control) I love it. I seem to understand how to set up tool and work offsets with one exception: How do you determine the X value for drills and taps in the turret? Obviously you want it set to the center of your part. Do you gist bump up to a known part and subtract the tool and part radius? Surely you pro's have a slick way of doing this without a probe.
Brian
Brian
