Hello Ohioturbo6,
You will want to purchase a machine cleaner like our Blasoclean AF as an example, to run in the machine sump prior to cleaning out the coolant system. After running the cleaner per the manufacturer recommended specified time, you will want to drain the dirty old coolant, clean all machine and sump surfaces with a high pressure washer (if available) and then run a diluted amount of coolant (usually 1% concentration) in the coolant system for at least 30 minutes. After 30 minutes, drain the flush coolant out and charge the system with the coolant of your choice, at the recommended concentration specified by the coolant manufacture. Please make sure to properly dispose of the waste.
Hope this helps!
Best regards,
Brett Reynolds, CMFS
Sr. Applications Engineer
Blaser Swisslube Inc.
