Trochoidal was a great improvement to straight slot milling for me. I use EdgeCam to program these paths around 5 years ago. The evacuation of chips and less then full engagement of the cutter allowed for higher speeds, but more importantly deeper cuts. I say 5 years ago, because the new roughing paths called "waveform" in edgecam are similar to many other highspeed tool paths. They run a constant cutter engagement and do loops in corners to avoid complete tool burial. This tool path has eliminated my need for trochoidal. All of this depends on material shape removal, tool entry and chip evacuation. Your cutting parameters aren't off much. I usually start at a lower SFM for 304 and work up to where I am comfortable. I usually nominally run 1200-1500 RPM with 3/8 EM in 304 120+ SFM.
What software is generating your tool path? If it is in the center, are you drilling a start hole and then entering there? That's what I'd do. Then I'd bury the endmill to .850 deep and flood the crap out of it. If your speeds and feeds are a bit slower it won't matter because you can take 3x the depth of cut. Full depth will allow your chips to evacuate. Of course I'm picturing suspended in a chuck or off the table on blocks. I hope this is helpful. I feel that many others here have better advice, but this is my best stab at answering your question.
