I'm trying to put a 3.625" bore through a 1" piece of mild steel (1018 or A36). The piece is 6"x9" and is held in a Kurt vise on 3/8" parallels, so the workpiece should be solid. I drilled a .625" through hole for entry. As programmed, the bore is roughed by spiraling out with a 1/2" 5-flute Helical coated endmill with 1.25" LOC. The cutter is held in a TG75 collet with 2.75" gage length. The machine is a Trak FHM7 bed mill. Using the manufacturer's most conservative speeds and feeds, I should be running full depth at 3660 rpm (479sfm) and 57.8ipm.
Where I'm having trouble is that no matter how I feed it, it sounds absolutely terrible, with tons of squealing. I was originally using a TG100 toolholder with 4" gage length, but switching to the shorter holder didn't make a difference.
Daniel
Daniel
