trelos_zoi
- Dec 20, 2010
- Cape Girardeau
Currently having some issues with Y axis encoder on tree model vmc750 with yaskawa drives.
Gonna pull Y axis servo motor to send off for evaluation however it won't seem to come loose after removing 4 bolts on motor. It will spin but won't come out.
Any tricks to this before I tear something up? I can't see anything else inside the Z column, if I could, I couldn't get to it or is there something else on the table side that needs to come loose? If so the motor could come out with a rather long shaft attached, so hopefully not because I only have about 3 ft behind the machine to wall...
My problem is I have no idea what the coupling looks like so I don't know if need to be more aggressive or go from another angle...any help would be appreciated.
Thanks!
Thanks!
