ZachN
- Nov 17, 2013
- LeMars, IA USA
I need some help with tapping.
I have a Cincinnati Sabre 750 Mill with Acramatic 850 control.
It does NOT have ridged tapping.
I HAVE tapped with it before.
I used a G84 and a spring loaded tap holder.
I am trying to tap a 1/4-28 hole.
The code is as follows:
T21 M06
G94 X.5005 Y-.135 S300 F.01 M03 M08
G00 Z.5
G84 Z-.7679 R.1 F10.713
X1.5005 Z-.7679
X2.5005
X3.5005
X4.5005
X5.5005
G80
When I try to run the cycle I get error 15214 - TOOL ABSENT OR DATA ERROR
Which according to the book means I dont have the tool data table filled out completely or something is wrong.
In the table I have:
Tool length as touched off to Z0
Diameter deviation .25
Number of teeth 4
Tool Type Tap
Angle 118 - what should I use for an angle on a tap? pretty sure thats what I used before was 118.
What am I missing or what else could be causing the error? I have done quite a bit of tapping and not had this much trouble, except its been a while since I did it and I am rusty....
The manual for the machine shows VERY LITTLE info about tapping.... Just says G84 is the tapping cycle....
Any help would be awesome! Thanks in advance, ZachN
T21 M06
G00 Z.5
X1.5005 Z-.7679
X2.5005
X3.5005
X4.5005
X5.5005
G80
Number of teeth 4
Tool Type Tap
