Hello everybody, Ive been banging my head against a 12,000lb paperweight for a little bit and have come to a crossroads. We are trying to decide to either fix the existing controls or retrofit. I would have already gone the retrofit route but it has mitsubishi drivers which everybody says are proprietary.
Machine is a Mighty Viper VMC 950, 20x40 3 axis mill, 20 position tool changer, 1999ish and some stupid low hours. By low I mean all the paint inside is still intact. Its Meldas or Meldas Magic running on a 486 w/ windows 95.
Machine worked great 2 years ago. It was running small jobs here and there, mostly aluminum. It went dormant for a while as other business ventures were pursued but are now needing the machine but after dusting it off we discovered some major problems.
All of the parameters were wiped out of the NC card. After a few days of messing with it, restoring parameter backups, formatting the card, restoring again, kicking the machine, and apologizing to it we have finally gotten it to run some simple programs, but we are unable to run anything more than moving the table around.
Unit goes into alarm when trying to toolchange. (first, toolchanger is off, but thats expected) The spindle wont index.
This weekend we are going to try to restore again but doubt that will work. We might even type in our paper copy of the parameter file to import but even then that is a shot in the dark. Instructions are non-existent and we havent had luck with the manufacturer in the past. They just want to sell a new hard drive to us but thats not where the problem is. Also Im not even sure if the NC card has some electronic problem or not.
Thats what brought us to retrofitting. We looked into that, going the Centroid route, or Mach3, but the problem is the servo drives are the mitsubishi ones that run SSCNET from what I gather so I would have to replace the drivers, which exceeds the price of just replacing the mill. (And us being a startup without a definite "this will make money" a retrofit north of $10k is hard to swallow.)
Does anybody have any tips or pointers? For now Im hoping to get the existing controls working, at least until I can get this thing printing money.
