Machinery_E
Titanium
- Aug 19, 2004
- Ohio, USA
Wired up one of the new Mori SL-1's, and am getting a "reset EMG" message. No other alarms and everything else looks normal, with no fault codes on the spindle drive, or the control. Of course the E-stop bottom is off. Also pushed rest on the control. Phases are connected correctly, and have hydraulic pressure. Safety interlocks are okay, if you try to open the electrical cabinet doors it kicks the main breaker off. Machine parameters look intact, its been without power for apprx. a month or so.
What has me at a loss is that there is an "Emergency release" bottom on the side of the machine operator's panel. It looks like it may be wired in with the E-stop bottom. Pushing it does not remove the reset emg message.
Before I pull my hair out any further, is it something simple I am missing here?
Thanks!!!
Thanks!!!
