I have a Medical "Castle" Untrasonic cleaner that holds 47 liters, it's 1000 watts of cleaning and 1500 watts of heating. It has both a foot and button operated power lid with a programmable timer that opens when it is finished. It can automatically fill itself to level when hooked up to water (preferably hot) and it has a degassing feature too. When instructed it will drain itself to a sewer if connected and can automatically add cleaner via a venturi mixer to a concentrated cleaner if desired.
My understanding is that it was used for cleaning surgical tools at a hospital. Probably a good thing to get it right from the source because it probably did cost an arm and a leg new. Like steve-l, I lucked out and picked it up off a guy who bought it with a bunch of other stuff at a clearance auction and he didn't even know what it was.
You probably already know why you should get a one, but just to show what my unit has done, and why a bigger one can come in handy!
My two limit switches for my lathe. Didn't even take the plungers apart to clean it.
Took my spindle chiller off one of my mills:
Before:
Just about in:
After:
What you are seeing between the fins is just water in that last photo. The cleaning was INSANE. Absolutely the most effective way to clean that heat exchanger.
My cleaner of choice is Simple Green HD (Purple in colour) it is pricy but it works astounding on Aluminum in particular. I read it is just rebadged and dyed Simple Green Extreme Aircraft and Precision cleaner. It can be found at Home Depot here in Canada.
For motorcycle carbs it is just incredible how perfect it cleans them. You know when you want to spend the time to get every speck of dust and grime off every spring but just don't want to tear them all down? This cleans that well without even taking them apart, minus the float bowls. I use it to clean turbochargers fully assembled too. No balancing required.
Lastly, to save on drains, heat/power, fumes and just general volumetric efficiency of the unit, I put my parts in ziplock bags with cleaner in the bags only. This way you can use a variety at the same time and if some parts are absolutely filthy you don't just make the whole tank black instantly. Cleaner goes a long way too.
The better quality you can find, the more you will save long term, just like anything I guess.
Nerv
