Spencer in NH
Stainless
- Jan 22, 2007
- Southern New Hampshire
I have a project where I need to cut a pocket about an inch deep with a .065 radius in the corners. The dimensions are .42 x .17-in.
If I use a 1/8-inch end mill, that's about an 8:1 length-to-diameter ratio. Not sure how to approach this. I need a surface finish of at least 32.
I suppose I can remove most of the material with a 5/32 endmill and then just deal with the corners.
The material is nominally 6061-T6. Machine has 10K RPM and is tight.
Any help would be appreciated.
Thanks.
Thanks.
