I am like totally ignorant. I hope that doesn't bar me from these informative forums.
I don't even know what 'CNC Machining' means and I only post in this forum because there was another thread in it about drilling stainless steel.
Unfortunately the answers that guy got are altogether too technical for me.
I need simple answers.
And I need to try and put my questions simply:
First: The job is simply to drill a hole in a stainless steel cleaver (About maybe 4mm thick) so's it can be hung up out of the way of the kids.
Second: I've made a start on it. I started with a normal drill and realised it wasn't getting anywhere after a while, went and got a couple of titanium coated bits and shopped further and got some 'panel drill' (whatever that means), double ended, cobalt coated.
I've even bought a 5 speed drill press (thought it was about time I had one).
Third: Where I'm at now and the puzzlements I'd like someone to please help me with:
The panel drills said 'don't quench in oil or water' - does that mean don't use oil as a lubricant during drilling. Or are they referring to dipping a red hot drill in a bath of it?
i.e., should I use oil or not?
Or should I use the 'cutting fluid' I read about in that other forum.
The bits seemed to get too hot too quick at the higher speed so I've moved the speed down to 800 and it seems to be happier there - but virtually getting nowhere.
Question: is this supposed to be a long, long, grinding away process or should I know something 's wrong if it's not done in a minute or two?
i.e. is that speed okay?
i.e. is an apparently 'going nowhere' cutting thing in the hole okay? Or should there be shavings?
I went back to the titanium bit because it is smaller diameter (I'm at about 2 or 3mm). And I ran it without any oil. It made enormous squealing and strange sounds and generated little particles of dust.
Is that 'squealing' a good sound or does it mean I've buggered the drill or something?
Are those little particles what we should look for to know stainless drilling is proceeding right?
Considering all of the above - smoking hot oil in the hole, oil in the hole, squealing, running at at about 1500 first, now grinding away for minutes (going nowhere) at 800 - what's the chances I've hardened the stainless and should just give up?
Can anyone please set this mug beginner right?
regards,
ab
regards,
ab
