UNJF Threads
Results 1 to 10 of 10
Thread: UNJF Threads
    Jan 2004
    Chicago, IL
    160
    7
    Default UNJF Threads
    I'm making some parts with a .375-24 UNJF-3A threads. I have the proper insert for the "J" threads and have a .375-24 UNJF-3A "go" thread ring gage, but for the no-go gage I only have a .375-24 UNF-3A (not J). Can I use a UNJF go and a UNF no-go gages to check the threads, or do I need to have UNJF go and no-go gages.
    Thanks for the help,
    Dave
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Quote Originally Posted by Flash Gordon View Post
    Dave
    Dave,
    Lets see if I can explain this correctly... it's been a very long time since I had anything to do with this sort of problem... but here goes.
    Your making a part with a male thread and the J means it's a controled radius root thread..
    For a low limit NUT to work, your male thread has to have a Pitch Dia near that low limit.
    The controled radius has to be ground into the GO thread gage so it must go on. If the thread you make does not have the controled radius root, the GO gage may not go on because of interference with the crest of the GO gage and the root of your male thread..
    Now for the NOT GO Ring gage, it should have a PD slightly smaller than the PD of the male parts smallest allowable thread your making so that IF it goes on, the PD of the part is deemed to small and not an accpetable part... if that condition exists then the root radius is not so much a problem, the part is undersize and scrap.
    Therefore, I believe the same NOT GO Threaded Ring Gage for a standard thread is also used for a J threaded part...
    If I'm wrong, I'm sure someone will be along shortly to explain why and how.
    May 2010
    Denmark
    17,420
    3541
    10234
    I found this by Googling when writing in another thread.
    Unified National J Series vs. Unified National
    Gary E is (almost) right but the link help explain things even more
    The guy (Wayne aka gageguy) that gives his email at the bottom of the link is in my opinion an expert and I don't think there is much he doesn't know about gages.
    Jan 2006
    Houston, TX
    6,087
    565
    1027
    Quote Originally Posted by Gordon B. Clarke View Post
    I figgered it would be you to say "almost"
    Now... just zactly where and why are you saying ALMOST ???
    Jan 2004
    Chicago, IL
    160
    7
    The Practical Machinist experts have come through again! That is exactly the info I was looking for. Thank you very much!
    Dave
    Jun 2006
    Hawthorne, CA USA
    171
    35
    58
    Default j threads
    Depending on you customer they might not allow gauges to be used.
    We are required to measure all J threads. This is done on a optical comparator with 100x lens. On a .375-24 UNJ the root radius requirement is R .0063-.0075. Ring gauges will not check that feature they are only made to clear the root radius. With go no-go gauges the flank angles can also be out of spec. but still gauge good.
    If you have the equipment to measure the thread you can avoid using ring gauges for external threads.
    Jan 2004
    Chicago, IL
    160
    7
    You are correct about measuring the root radius. My QC dept measures the thread and root radius on the comparator, but it's nice to have the gages at the machine for set-up and in-process checks.
    May 2010
    Denmark
    17,420
    3541
    10234
    Quote Originally Posted by Gary E View Post
    You'd be great as a lawyer if nitpickin' was bone fide specialty. "Almost" can be up to 99.999999999999%. If you were 100% certain that what you wrote was correct why not just write that?
    My post in my opinion agreed with you, but as to 100% I'm just not that certain myself that what you wrote (sensible as it was) was 100% of the whole truth without really going into the two standards with a microscope.
    You really should relax
    Aug 2005
    CT
    7,544
    249
    1545
    Well, since we're nitpicking, about the only thing Gary was "almost" 100% is that the go gage does not have the root R ground in, rather it's truncated to clear the root R.
    This however brings up an issue Flash will have to take into consideration.
    Since the Go-gage does not reach near the root of the thread, it is entirely possible that the gages ( even trirolls ) will show a perfect thread well within the tolerance, yet the shadowgraph shows a messed up rootform.
    This typically happens on Inco, where the insert tip either breaks or wears off, yet the pitch is still perfect.
    Just be sure to have some good procedure to take the extra step and look on the projector and not simply accept the results of the gages!!!
    I can send a few pounds of Inco625 - 1/4-28 UNJF parts to set a bad example.
    May 2010
    Denmark
    17,420
    3541
    10234
    Quote Originally Posted by SeymourDumore View Post
    Yeps a "perfect" thread is just about as hard to make as it is to measure.
    By "perfect" I mean that every single dimension is within tolerance and that includes flank angle, pitch and radii.
