zoeper
Cast Iron
- Jul 8, 2010
- South Africa, Cape Town
Hi Guys,
On Saturday night my mill packed in again. I had problems with the Y-axis Brushed DC motor before and cleaning the carbon from the motor fixed that problem.
Last night, mid cut, the machine tripped out with a servo disconnect alarm and I have been unable to get it running again.
When switching on the servo circuit, the machine will hum for a second while the fault light on the Y-axis servo comes on, and then it trips again with the same fault. Removing the servo motor confirmed that the axis moves freely, and applying 12Vdc to the motor confirms it also runs smoothly.
When I switch the drive cards between axis, the error follows the y-axis servo amplifier.
The fact that I was working at 23:30 on Saturday night should confirm the convenience of this little breakdown
I will take the drive card to someone tomorrow to see if they can repair it, but I need to also get some sort of replacement(s) to ensure I do not get stuck up this creek again.
Browsing around brought me to Advanced Motion Controls B25A20 brush-less servo amp that can drive both Brush-less and brushed motors.
Question is: can most "brush-less" servo amps be used on "brushed" motors?
How do you calculate the size of the brush-less drive to drive a brushed motor?
What would be the make/ models to watch out for?
I see a lot more Brush-less drives floating around on eBay and if usable, I should be able to replace all 3 drives with newer tech drives.
The old drives are Anilam drives that was only sold in the UK, not the Westinghouse drives that was common in the US.
Control is a Anilam Crusader GXM.
Motors are SEM DC servo motors rated at 140V and 58A pulse current, 3000RPM max.
All the electronics on this machine are getting very long in the tooth, hence the reluctance to splash out on new drives. Ideal would be to get it running for another year or so, and then replacing with a much newer machine with tool changer, faster spindle etc. If the control packs in, I might be forced to retrofit, making an upgrade to newer drives worth the cost/ effort.
Opinions and advice much appreciated.
