CNCME?
- Feb 23, 2008
- USA, South
Hi all,
I just bought a shelf full of miscellaneous tooling from a friend, in the trove came some (1/2 dozen or so) wavy toothed design end mills.
One that is representative of the group is marked Americut W-110938 2" DIA D89 HS USA. 2" Diameter and HS I understand. Made in USA seems simple enough. I'm wondering what the intended machining material and envelope of these were? Feed, speed, depth of cut, suggestions would be a real help. I'm guessing Aluminum was the intended material? 8 flutes, flutes about 2" in length, razor sharp, Weldon flat on the shank, looks like an 1-1/4 diameter shank, not center cutting. On the shank is Weldon K4564 8 E88 HSCO USA.
I would be using this in an older Haas VF3.
I've tried searching the archives here, and on the general WWW, but no luck.
Thanks for any help / info., or just general tips on their use, if anyone has some experience with these.
