Is a probe in a spindle generally accepted as less accurate than a cmm? Of course the mechanics are different, how about the software? We have had repeat issues in our cmm room. Same part measured twice with slightly different reports.
As a rule of thumb I'd say a probe in a spindle is 5-10X less accurate than a cmm.
Depends on your machine tool and your cmm.
Do not confuse accuracy and repeatability. Different animals.
And then linear accuracy and volumetric accuracy, one typically 3-9x worse than the other.
It is possible to make a probe in spindle repeat as well as a cmm with the same feedback resolution but you have to do your homework.
It will not be accurate and machine tools use backlash comp which screws all this measuring stuff up if you probe from two directions.
Even with glass scales mean ole mister Abbe comes to visit.
The repeatability Tony refers to is a latency issue (although some mechanics in the probe are involved).
You touch a point and break a switch while moving. This signal runs at the speed of light through your wire to the computer, some lag here.
Then the computer has to see your signal and quickly read the number off of the moving scale. More lag here.
So by the time you read the scale the probe is past the position where the touch occurred.
If you do this with an interrupt the amount of time to service this request is variable so you get bouncy numbers.
Sometimes the cpu gets there fast, other times not so fast. Jitter in the real time world.
Often in a CMM design you will hardwire a position latch to the probe so the scale reading is captured and held by hardware circuity but even this can only repeat with +/- 2 counts. Perhaps worse if you are using sub-dividing circuitry in between (variable lag depending on clock synchronization) and most do use this circuit in between to get the resolution users want.
Like a part draw in cad it all looks easy and perfect from the outside. Not so much when you have to build it and make it work.
From the floor side it gets stranger still if you have 20 cmms.
Some say good, others say no and operators know which ones agree with their floor gauges.
All that said I'm a big fan of cmms on the floor at every machine group.
Programming is programming, not hard once you learn it and should be quick.
Time to check depends on what you need to measure.
You may have some arguments between your floor machine and the big guy and have to figure out how to deal with this dispute.
Ziess is sort of the gold standard as they do build some of the best high end but many options just as good in the workhorse side.
The nice thing about a cmm or other automated gage is that it has no bias towards a good vs bad part. You eliminate this built in human tendency from your measurements.
We all want to make good parts and consciously or subconsciously we will all bias our numbers towards zero, computers do not care.
Bob
