vmipacman
Cast Iron
- Nov 21, 2014
- Virginia, USA
With a spring pack drawbar properly tensioned should the drive blocks in the spindle nose see any wear from toolholders? I have a CAT 40 spindle. The drive blocks had wear when I got the machine, I flipped them around so I could see for myself. They have a little new "hammering", I suppose you could call it. Otherwise the drawbar and cutting finishes seem to be fine. I only use about 20% of the machines hp, so not a ton of load. Is this the first sign I need to rebuild the drawbar?
Thanks!
Thanks!
