Since I am a HUGE fan of gang lathes, I strongly encourage you to look at the Haas CL very very carefully!!!
First, it has a pull-type mechanical closer.... cheap enough alright, but if you get any variation on your bar size ( nylon might be a good candidate here )
you will get all kinds of pushback.
Second, it comes standard with a built-in shower unit by way of that airplane door they've put on it.
Third ( though won't matter much for plastic parts ) the spindle is approximately half as long as a 50 year old Hardinge chucker has, probably half as rigid too.
Of course, I am a bit biased because I own a Haas MiniLathe. If they were available still, I'd get another one tomorrow morning.
For 45K you're really scraping the bottom of the barrel however, not sure what's out there in that range, Ganesh perhaps?
