First thing would be what year? And actually that doesn't matter too much, what control does it
have? The 88 or the 88HS. I heard that some of the early 88HS controls were in the old 88
pendant because they still had some left on the shelf..
May be a moot point if they updated everything anyways. Early 90's was DC drives and motors, which
aren't brushless so they require more maintenance (supposedly). Not a deal breaker, I find the DC amplifiers
to be more robust than the AC and if they do blow up, about half the price as the AC's.
As for the 4th... Fadal did it simple.. The control can do every and anything, it was all there, extra offsets...
already there... Ability to rigid tap... already there... Macros... not an option, already there.. Run 5 axis..
already there...
Really the only options where hardware related. Does it have the e-proms to rigid tap, and a spindle drive that
can rigid tap? Probably already has the encoder in the spindle motor, both my machines ('93&'94) have the encoder,
but not the e-proms. 4th axis.. Need the controller card, axis amplifier, a cable and a 4th axis... All hardware...
Anyways, yes it will be a full 4th.. You can do full 4 axis moves, though you will probably never have to, I think
I've done it once, may only have been a 3 axis contouring move, but it will do it.
One other thing to look for, a lot of 4020's that came with a 4th have the extended 28" Z axis.. This is
VERY handy. Easy to tell. If the top sheet metal on the left is a mirror image of the sheet metal on the
right, its a standard 20". If the top sheet metal on the left has a cutout for the tool changer to fit, its
28"... The cutout weakens the top sheet metal on that side, so you can't stand on it like you can on the right.
You can also check the parameters by typing "setp" then enter from the "enter next command" prompt. 3 simple pages
worded in english. There will be a line that says "screws" and it will say either "inch" or "metric". Another quick way
is check the pitch of the Z screw with some calipers.. The Z screw is an 8mm pitch and easy to get to. The inch screws
were a finer pitch.
How much are they asking?
