Results 1 to 8 of 8
    scadvice's Avatar
    scadvice is online now Stainless
    Jan 2009
    "Stuck in Lodi", Ca
    1,011
    Question What oil for linear way Akira Seiki lathe?
    I have a linear way Akira Seiki lathe and do not have the maintenance manual. Can someone who has one tell me what oil you use to lubricate the linear ways?
    It's most likely the same for most linear way machines...but I thought I'd ask.
    Steve
    Mar 2007
    Hamburg, Minnesota, USA
    1,471
    I have 3 linear guide machines, 1 is a greased way, other 2 are oil, I use Mobil Vactra #2
    Dave
    Dave K is online now Diamond
    Mar 2004
    Waukesha, WI
    4,800
    1 is a greased way
    Hardinge sold one to you too, huh?
    scudzuki is offline Stainless
    Aug 2008
    SouthEastern Pennsylvania
    1,027
    Greased rails... could be a Cinicinatti.
    Joe
    Mar 2004
    Waukesha, WI
    4,800
    Oh, really? I though Hardinge was the only one doing that. It's the only one I've heard of anyway.
    Didn't realize, this may be more common than I thought. Hardinge says to use Kluberflex, (I think that's the name of it). It's slightly over 100 bucks per tube.
    Mar 2007
    1,471
    Bzzzzt
    Milltronics Partner 6 (greased) (400 ipm rapids slow by todays standards)
    Milltronics Partner 1 (way lube) (320 ipm, figure that one out, same motors, same screws)
    Takisawa TC1 lathe (way lube) (400 ipm in X 800 in Z)
    They never really told me to use anything special for grease, it was recommended to use a good wheel bearing grease, can't se any wear on the rails so it must work, been using it for 8 yrs
    It does help keep the skank out of the coolant tank though. I don't push it 24/7 so it's not really an issue. I does take a couple hrs to grease it though. Have to pull all the guards to do it.
    We had a newer one at work, VM17, that had a common grease manifold, could grease that one in about 10 minutes.
    Dave
    Aug 2008
    1,027
    Cincinatti specifies several different brands of equivalent greases.
    I found the Mobil variant at McMaster, I think it was around $20/tube, not too bad.
    Joe
    scadvice's Avatar
    Jan 2009
    "Stuck in Lodi", Ca
    1,011
    Thumbs up thanks
    Thanks for the feed back.
    Steve
