turbotadd
- Jul 22, 2010
- Stillwater, MN
That's interesting. They wouldn't happen to be for an educational institution, would they? I ask because the local college asked us to make a bunch of parts for the indy car team, one of which was that very same part. The company I work for only wanted to donate a weeks worth of machine time, so I ended up just doing the turning work and they said that they'd handle the milling work. I too was stuck with the dilemma of how I was going to do that feature, but ended up not needing to because I ran out of time. I was initially planning to find a reduced shank 3/8" end mill as has been suggested.
Good luck.
Josh
Looks like a cnc ram type edm . . . easy job for that. Or wire cut the profile thru and plug as needed.
9X deep, no need for EDM.
Those reduced shank endmills are miles ahead of a fluted tool of the same length. The different in rigidity is
pretty amazing. Probably won't set any speed records, but I wouldn't be worried or be sweating about running a reduced
shank endmill in there.
I'd probably run it with an ER32 or 40 instead of an ER16, just to grab as much of the shank as possible. The biggest
problem is going to be getting the chips out. When you get down to the bottom the collet nut is going to shield your coolant.
I don't think I've ever had a melt down with 7075, so I might try it dry with an airblast. Though I would probably test that
out first with a cheaper standard length endmill first.
My eyes tell me that both drawings are way out of proportion!
Think Snow Eh!
Ox
Kept seein' lots of replies about a 3/8 mill, but the rad doesn't go all the way around. It gets clipped off at the wall.
Ox
Easy to draw stuff in Cad and then throw it over the wall to manufacturing.
Everything should be designed/drawn with an eye towards how to make it.Bob
OK - I'm seein' it now.
Apparently both the C/L rad and the outter spur rads are both .718R.
Or maybe the other is "The Mystery Rad"?
It is the corner where the outter spur rad meets the wall that is .188R.
I agreed that it looked like the outter spurs were a 3/8"D feature, but the pic Shirley didn't look like it to me.
The 2nd pic is bogus. Not gunna make that feature look like that with round tooling at all.
But the URH view in the first pic does show the secondary rad in the corner of the spur rads, right where the .188R is pointing on the other view.
The RH pic is poorly drawn and the LH pic is poorly labeled, but I get it now!
Think Snow Eh!
Ox
I see your point about where the 0.188 rad joins the wall OX, but the dim' arrow does point to that ''corner'' and not the middle of the larger arc.
Notice
