cdn farmer
- Oct 24, 2007
- Grimsby, Ontario
Does anyone know if using I and J values for arc moves is more accurate than just using R value,, this is on a Hardinge VMC1000 with an OM D control,, I do mostly aluminum parts and when running at higher feed rates there seems to be a bit of deviation from the programmed path,,Is there a parameter that can be changed for more block look ahead possibly or for tightening up the accuracy?
