I am looking for concrete facts or evidence that replacing older but otherwise geometrically perfect belts will do anything to improve noise, finish, etc?
I read where everyone seems to recommend "change the belts" but I have not once replaced a sync belt that did anything better other than make me walk lighter (cash). Some here recommend replacement for spindle noises, vibrations, etc but I have not found a sync belt reference yet that replacement actually did anything and I sort of suspect any improvement might be more from belt tension adjustment. Indications from Gates is that the belts won't stretch so unless there is wear or damage to the belts, replacement is not needed.
The reason I ask is I have a couple with a little memory in them from sitting. not perfectly round. However, they lock into the sprocket teeth like new. Even though they are old, I am trying to justify why I would replace them. ?
