Solar71
Titanium
- Mar 24, 2005
- Hermosa Beach California
Hey all...
Just finished my LONG part run...
We stoped at 50 units...
Now, tommarow...
Something new...
Damn, with all the ultra knowledge in this forum, i wish i could post blueprints without numbers...
Is there a way for my to post an autocad drawing without numbers, and without a way for you to figure the numbers out ? If i post an autocad drawing for you, and remove the numbers, and maybe take the image out of scale a bit, would you guy be abble to get the numbers from a .jpg image?
Anyway...
back to what i was thinking...
Tommarow there is this part, that i haveto make...
5 radii 3 angles surfaces, 2 chamfers , 1 center , and its ( aproximately ) 4.5 inches long... Dont know the exact steel it is...
But its Steel, and its Rockwell C scale 28-30 hardness...
So its pretty damn hard... Anyway... the stock is 4 pounds, and the finished part will be just about 2.5 pounds...
Basicly what i want to do it, face and center the part, bring up the tail stock, and machine the part at HIGH SPEED!!! ( as high as i can, that is ) Then i want to cut it off...
The cuttoff diameter is 1.770 and i was wondering... If i leave the tail stock engaged... How far can i cut before i should remove it ?
cut with tail stock engages untill there is .125 material left ? .250 ? .375 ? .500 ?
Or no tail at all ?
Also, lets say, i cut untill there is .125 left, in the center... i retract the tail stock...
then i plunge in for the final cut off...
What speed and feed should i use , so that i dont have these 4.5 inches of steel swinging all over the place... ?
PS : i did a nice long run of parts with cutoff and bar puller not long ago... But the part was only .250 long... and was drilled before cutoff too... so that was much easier...
this part being 4.5 inches long and 2.5 pounds has me a bit worried...
should i not worry, and just go for it... ?
is there something i should be carefull about... ?
PSS : this will be given to me in 6 foot long sections... I will be using the bar puller as well... There will be no spindle liner becuase the material is 2.010 and my spindle shafts ID is 2.060... so .050 extra... im not going to make a .025 thick donut... its not worth it...
Also 6 feet of stock means 1 foot sticking out the machine...
if no one is in the area, is that going to be ok ?
or should i just ask for 5 feet instead ?
PSSS : i love jobs where i got to use all the cool M codes!!!
thanks
Now, tommarow...
Something new...
Anyway...
Or no tail at all ?
thanks
