Wiring problem: Bridgeport CNC motor won't stay on unless I hold switch.
I just finished replacing a Contactor in my Bridgeport 2J head 2HP CNC mill with varidrive. When I was diagnosing the bad contactor, I found a loose wire and believe it may be the problem. The contactor was frozen in the open position. There are 2 Contactors with an interlock wired as a reversing contactor. When I turn on the starter switch left the low/forward (or high/reverse) works fine, but when I turn the switch to the right the contactor will only stay engaged if I hold the switch to the right. The missing wire is on the left interlock and stared on my drawing. I have pictures as well as I drew out the wiring as best I could. I don't think I can upload a picture large enough to be of use but I'd be happy to email them if someone can help. So far I haven't been able to find a relevant thread on the site.
I am not an electrician, but I do know the basics. I understand that the engaged contactor should be able to also close the control circuit until the current is broken with the Stop button. My problem is that this setup also has the CNC controller and other components that has made it much more complex.
As for my drawing:
Orange/black goes to High Speed switch.
Orange goes to low speed switch.
Red/black is common from High/low speed switch.
Red is a Stop switch.
White indicated on the sheet go to the thermal overload relay (pin 96)
From the bottom of the page, the DC current comes from my CNC controller I believe. The 2 white wires from my Emergency Stop button also go to the CNC controller and stop all axis movement as well.
As for my drawing:
