Richard/SIA
Cast Iron
- May 13, 2007
- No. Nevada
Looks like I may need to convert some G-code from Yasnac to Fanuc.
Searching the web I find post claiming there is very little difference between them, but what is different may be significant.
Without buying a specialized program at $300.00 - $500.00 is it reasonable to convert one to the other using just a post edit program?
Will a character search and change type edit work?
Must I be an expert at both to edit on my own?
May as well add that ideally I would end up with Fadal code but Fanuc will work.
