Yasnak MX3 help with memory issues
Results 1 to 17 of 17
    May 2011
    Mesa, AZ
    9
    Default Yasnak MX3 help with memory issues
    I bought an old but awesome Matsuura MC-600V. Learning a lot but still a newbie. Read through entire manual and says it should have a minimum of 256k of memory. I downloaded than deleted all the programs except for one small 5 line home program. Under the program it says it has 31k memory left. I tried to upload a small simple pocketing with outside contour and chamfer program and got memory over run. The guy who had it before me ran a 4th axis on it (not sure if that matters).
    Not sure if there are any 8000 or 9000 number programs, and not site where to look for them. I called yaskawa and he ran through a method to clear the memory but had to change some switches on , main pc board, followed by do exactly this or you will erase something else!!! Made me nervous, anyone have any advise.
    Thanks so much in advance, noobie but learning
    Fast!!
    Dan
    Jul 2013
    Indiana
    2,866
    4173
    1432
    Your probably going to need to drip feed to the control because of the no memory thing. Read this thread and do a search of the PM members username I think he sorted this out on his Yansac machine.
    Brent
    Yasnac MX3 drip feed - need help quickly!
    Jan 2014
    Vancouver, WA. USA
    2,701
    541
    1345
    The MX3 could have a memory as small as 8kb. I have never seen a builder select that small of memory on a mill. If your machine is showing 31-32kb, that is a common size selected by machine builders in that generation of control. Larger memory capacity was an expensive, high margin option from the machine builder.
    Both Tulip Electronics and Memex sell memory upgrades for the MX3, up to 1meg.
    Mar 2013
    NW Pa
    322
    39
    136
    Quote Originally Posted by dbramley View Post
    Fast!!
    Dan
    Press the alarm key and scroll thru using the page buttons it should take you to a screen that will show any programs that are loaded in the controller...and also how much memory is available.. thats how my mori
    works..
    May 2011
    Mesa, AZ
    9
    Thanks guys!!! I have been llama king into the drip feed option, I appreciate the link yardbird. The manual says 256k, but I very well could be mistaken. I called yaskawa and man I spoke with said sounds wrong. He gave me a procedure of setting switch just below battery rom7 then turn on. I got lost in his accent my ignorance of the subject. I think I will call back and ask him while I am in front of the machine.
    So to be safe I tried to output the parameters, it outputted them in NC. Should they be output in some other format?
    Again, thank you for taking the time to help me, I feel like I will have to write, load, run, then delete a program for each operation!
    Dan
    May 2011
    Mesa, AZ
    9
    Cmccull166, I looked and only program listed is one small 5 line program to home machine. Would any 8000 or 9000 programs be listed here? Could there be programs hidden? Like macros etc.
    Dan
    Mar 2013
    NW Pa
    322
    39
    136
    Sorry Dan thats all have.
    Jan 2014
    Vancouver, WA. USA
    2,701
    541
    1345
    The alarm/page down shows all programs in the memory. Macros will typically be 9000 series and are not hidden in this view. They can be locked out by parameter setting so you can not edit them though. If the machine has probing or a tool setter then there may be programs in the 8000 range. Again they would show in the screen and can not be hidden.
    The rotary switch on 7 and power up accesses a maintenance mode where the control can have various portions of memory cleared or the entire system generated. Generation in Yasnac speak is like formatting a hard disk. It will know it's a CNC, but it will be totally empty of all parameters including the PLC parameters. Without great backups that can be very difficult to recover from. Work in that mode very carefully and if you don't understand some part of it don't try it.
    May 2011
    Mesa, AZ
    9
    Thanks, I don't understand anything in that mode, and it makes me nervous. I suspect that if nothing has s hidden then 32k may be it. Looking at Memex memory upgrade. I don't mind moving programs on and off but as is I can not even make a simple pocket and clean it up on one program. Thanks to all who have given their help, I am sure I will have many future questions.
    Regards,
    Dan
    Jun 2008
    Toronto, Canada
    254
    68
    59
    I have the dame machine and it has 31k of available memory when there are no programs in it. Even when you drip feed (it's 4800 or 9600 baud) it chokes on code.
  11. #11
    May 2011
    Mesa, AZ
    9
    Thanks Steveo, may be time to look into a memory upgrade.
    Dan
  12. #12
    May 2011
    Mesa, AZ
    9
    So, looks like memory upgrade time for me, mncomputer is talking to the machine just fine. I downloaded the parameters using NCLink. The parameters downloaded in NC format with number lines and everything. Is this correct or do I need some form of text editor? If so is there one you would recommend? I just don't want to screw this up if possible��.
    Thanks again,
    Noobie
  13. #13
    Jan 2014
    Vancouver, WA. USA
    2,701
    541
    1345
    Yes, the parameter files should have line numbers. Post up a few lines of the file so we can see the format to be sure it looks OK.
  14. #14
    Jun 2008
    Toronto, Canada
    254
    68
    59
    Dan
    I used this machine for years with the machine memory and drip feeding.If you are doing simple parts with out surfacing or high speed tool paths, it works great. I have done a lot of surfacing with it as well, you just have to simplify your code.
  15. #15
    Mar 2013
    NW Pa
    322
    39
    136
    Dan
    I"ll be in AJ end of January,Put me up for the winter?
  16. #16
    May 2011
    Mesa, AZ
    9
    Here is a sample, thanks for everyone's help. Weather is awesome here these days,80+\-!!!
    [ATTACH=CONFIG]214707
    This look right?
  17. #17
    Jan 2007
    Pinckney Mi.
    2,988
    4326
    782
    No expert but my stock MX2 has a small memory, its got over a100 grams and still has room?
    something seems wrong, what i have no clue.
    the folks here can fix it for you,way smart they are if you can hold their attention.
    Gw
