Atomkinder
Titanium
- May 8, 2012
- Mid-Iowa, USA
Machine: Fadal VMC2216 CNC88HS Format 1
Question: The part I'm programming is pretty short, and it needs to sit with only about 1/8" in the vise. It's pretty much a mirror image part, and so I want to machine one side at at a time so it can simply be flipped and won't mill away a stop sitting on the left side (right side out of the vise). To do this I'd like to use a G52 to shift the X axis .05" and back again after an M0, but I have no experience using G52. Does it need to be canceled or will calling the work offset (E* in this case) cancel it again? Tried searching the forums, but most of what I come up with is examples for shifting work coordinates for multiple parts. Only making one of these right now but I don't want to program it again if we make more.
