Page 4 of 4 FirstFirst ... 234
Results 61 to 69 of 69
  1. #61
    adamshive is offline Plastic
    Apr 2010
    Lehigh Valley, Pennsylvania, USA
    43
    Quote Originally Posted by SchneiderMachine View Post
    Wow, it sure looks different.
    Yep.
    Even when I draft parts like this in my cnc program they won't use my drawings to make new prints.
    So they want me to draft but then they never use the draft to create a draft.
  2. #62
    alphonso is offline Stainless
    Feb 2006
    Republic of Texas
    1,275
    How do you make 3 1/2 + 1 15/16 + 1 1/4 = 7 1/4??
  3. #63
    SeymourDumore is offline Diamond
    Aug 2005
    CT
    5,466
    Alphonso
    That is one of the few things that actually add up on that miserable thing.
    3 1/2 + 1 15/16 + 1 1/4 + hole location from edge = 7 1/4
  4. #64
    jdj
    jdj is offline Diamond
    Oct 2007
    detroit,mich.
    4,475
    Quote Originally Posted by js412000 View Post
    I am not being sarcastic. I quite often start a project with a drawing that has no dimensions.
    When that happens I question the initiating person as to what his desires are and "invent" dimensions and tolerances and select materials that will allow the part to function properly.
    That, is another situation. NEW parts that are being designed by YOU and (fill in the blank).
    Jeff
  5. #65
    jdj
    Oct 2007
    detroit,mich.
    4,475
    The drawing does not look that bad.
    When my boss gives me a pencil sketch with no
    dimensions and not drawn to scale, I don't complain.
    I just get on with it!
    I consider it to be annother opportunity to please him.
    PLEASE HIM, huh? I bet!
    Jeff
  6. #66
    stroker is offline Cast Iron
    Jun 2006
    Melbourne Australia
    410
    All of our manufacturing drawings bear the instruction ' If in doubt ask - do not proceed without clarification'
    I'd be doing plenty of asking until the lazy originator gets the point and the delays are highlighted to those who should care.
    Cheers
    Miek
  7. #67
    Matt@RFR is offline Hot Rolled
    May 2004
    Paradise, Ca
    966
    Quote Originally Posted by jdj View Post
    Jeff
    Exactly. I just got a cardboard template with a few notes on it, one switch that needs to be fitted (four times), and one screw that they want to use to fasten this thing down taped to the back. It's for a car builder that has no CAD capability. This is fine, and they pay me to make the model to machine from. They answer any questions I have promptly and they pay promptly. All is well.
    But for a "professional" to do the above, or worse, what Adam has posted pictures of, is grounds for execution by humiliation.
  8. #68
    implmex is offline Stainless
    Jun 2002
    Vancouver BC Canada
    1,108
    Default Some further thoughts
    Modelman wrote:
    " Likely, the "engineer" who is providing these layout drawings has a multitude of other responsibilities, and rightfully feel that he's not the friggin draftsman; that's what the guys who program for the CNC punches are paid for."
    JS412000 wrote:
    " Your boss has carefully considered all his options and chose to task you with the job of making parts from less than ideal drawings. Most managers are open to suggestions but if you can't do the work then he may have to hire someone who can."
    What neither of you seems to have picked up on, is that adamshive gets crapped on for doing these things and is cut no slack when the dodgy info he gets leads to a mistake.
    This is not a case of "Here, I don't have time to do this properly, please finish it up for me".
    It's more like a case of "What the hell is wrong with you...you take too goddam long and you f*cked it up on top of it. It's all right here on the drawing. What the hell is wrong with you"
    All of us know how to work from less than perfect information but there has to be some ground rules about the compromises needed to work this way and one of the main ones in my opinion is: "Don't piss on the guy who's trying to help".
    BTW, there's a good chance the old engineer is scared stupid of the computer, and has never learned CAD.
    Adamshive hints at it with remarks like how he managed to wipe the unwipeable title bar, that he doesn't know how to dimension with the dimensioning tool, and that he hand sketched on a TIFF file to get some information out to the shop floor.
    He's probably defensive and obstructionist because he's scared of losing face in front of everyone from such a young pup...that's likely why he won't even use the amended CAD files he gets from adamshive.
    So here's a thought for you adamshive: can you find a diplomatic way to help him out?
    If you do it right you might have a friend for life, and you might get a chance to tap into the stuff he knows well and broaden your own knowledge for free...it might be worth a shot.
    Hell...you might even turn the company into a good customer when you go out on your own!
    Cheers
    Marcus
    Implant Mechanix – Design & Innovation - home
  9. #69
    Hole Wizard is offline Aluminum
    Nov 2006
    Austin, TX
    119
    Those drawings are bogus. (Not to mention the stacked tolerances on the plate)
    My only tip is to grab a handful of different color highlighters choose a different color for each feature & mark up the "print" before you make a real drawing. When you draw it use the matching color per layer. Yellow= A Blue = B ect...
    It's bogus, but sometimes you've got to "kolor wif da big crayonez"
