Hi everyone,
I'm having some trouble with my "new" Mori TV-30.
The machine was fully functional but lost the
absolute positioning after backup battery failure.
It comes up with the following errors:
Z70 "ABS illegal Error" 0101 XYZ2
M01 "Operation error"
S52 Servo Alarm
Oil Pressure low
(Machine Mori Seiki TV-30 APC, MSC 802/Meldas 50M)
I'm unfamiliar with the Meldas Control and
somewhat stuck. The manual says that these
need a new zero point adjustment, and I have
the procedure detailed in the manual.
Z axis zero point should be set with a 250mm
gauge block between the spindle nose and table,
not subtable. Any ideas on what I should use
as the reference table? The machine is with APC,
and the manual isn't very helpful.
The machine also refuses to move the axes,
swap pallets or do tool changes. It doesn't go
into MPG mode, which means I can't do the zero
point adjustment. Any thoughts or tips about
setting the zero points would be greatly
appreciated.
Also, is there a way to back up parameters to
memory card or by RS232?
Cheers,
Harri
S52 Servo Alarm
Oil Pressure low
appreciated.
Cheers,
Harri
