will gilmore
- Feb 6, 2007
- New York City
I don't have cutter compensation but I can program helical movement. My question is: on the lead out from the cut does the cutter move in a flat arc in XY (Z is axial to thread) or does the cutter arc out in a helix so as to be tangent to cutting tool path. Today I'm working on 1/4-20 but I'm curious about best practices.
I've successfully programmed single point threads on a through hole where I started the helix below the material and ended above. I've done a NPT thread with a multipoint tool. I sketched the helical leadout in CAD and everything was fine. Downside is I had to go back to CAD a couple of times to dial in the fit so I'd like to be able to adjust the program at the machine. Programming the helical leadout will take some thought.
