Tips for turning parts on manual lathes
Results 1 to 5 of 5
    May 2009
    Illinois
    582
    10
    153
    Default Tips for turning parts on manual lathes
    By Tom Lipton
    Click Here for a free subscription to Cutting Tool Engineering magazine.
    The following are tips for enhancing the operation of a manual lathe.
    • Machinists can do small work on large lathes but not large work on small lathes. Therefore, buy a lathe a little bigger than you think you might need.
    • Put target score marks on raw material for fast roughing. Touch off the tool and use a scale to make reference marks so you can reduce measuring time. Rip and tear down close to the lines and then pull out your finer measuring tools.
    • Use quick-change tool posts. Make sure you have plenty of tool blocks. I hate it when a lack of tooling interferes with productivity.
    • Always leave a boring bar set up in a tool block. A good starting point for general-purpose work is a ½ " or ⅝" boring bar. When tooling the bar, use indexable inserts if many different people use the machine so they can quickly change inserts, if needed. CCMT or WNMG inserts are a good compromise. You can switch insert geometry easily for different materials. WNMG inserts have six cutting edges, providing good economy. We set ours up with the thought of having one insert optimized for harder materials and one for softer materials.
    Ch05.Fig002.Lipton.DSC_0485.tif
    All images courtesy of T. Lipton
    Put score marks on raw material for fast roughing.
    • Set up a dedicated turning tool block so it misses the quill on the tailstock when the tool point is on-center. This eliminates repositioning the tool when using the tailstock to support work.
    • Keep two parting blades set up: one neutral and the other with a couple of degrees left-hand angle.
    • Keep a long, double-ended, 45° chamfer bit set up all the time at each lathe. It is extremely handy for edge breaks and quick facing. The double end allows you to use it on both axes’ ID and OD.
    • Never modify someone else’s hand-ground tool left in a tool block. You might as well ask to borrow his toothbrush. Just take it out and leave it on top of the lathe.
    Ch05.Fig005.Lipton.DSC_0474.tif
    A double-ended, 45° chamfer bit is handy for edge breaks and quick facing.
    Ch05.Fig006.Lipton.DSC_1134.tif
    Step boring deep bores in two or more steps leaves more room for chip evacuation.
    • Always leave the lathe in better shape than when you found it. This has the added benefit of highlighting the shop slobs. They stand out in stark relief against a clean background, where they can be properly whipped and chastised.
    • Use a DOC that is a little larger than the tool nose radius. With inserts, the chipbreakers do not function unless the DOC is larger than the nose radius.
    • To minimize chatter, apply a tool with positive geometry, a small nose radius and a lead angle near 90°, especially when ID boring. The tool tip should be on-center or a few thousandths of an inch high.
    • Step-bore deep bores in two or more steps. This leaves more room for chip evacuation, and you can use a boring bar that fills the bore more completely.
    • Carbide and heavy-metal boring bar shanks are much more rigid for deep holes. You can buy the heavy-metal material and make your own custom boring bars. The longer bar in the photo on page 29 showing two boring bars is a rigid heavy-metal one called “No-Chat.” It can be machined into any configuration and lives up to its reduced-chatter advertising. The shorter bar in the photo has old, broken ¼ " carbide endmills for tool bits. Every shop has an endless supply of broken ¼ " tools that can be reused in this boring bar.
    Ch05.Fig008.Lipton.DSC_2844.tif
    The shorter boring bar uses broken ¼ " endmill inserts for tool bits, and the longer bar is made of a heavy-metal alloy to reduce chatter.
    • When you have chatter, try increasing the feed rate before you slow everything down. Another trick is to move the boring bar in the holder a fraction of an inch in either direction. Sometimes this small change in the resonant frequency can reduce or eliminate chatter.
    • Always try to increase cutting speeds and feed rates. If you never push the envelope, how do you know where the limits are? A 20 percent increase in feed returns a greater reduction in part cost than a 50 percent increase in tool life.
    • Test new tools once in a while. Lots of smart people are working on some effective new designs. Besides, it’s fun to test a salesman’s tools at full throttle. CTE
    About the Author: Tom Lipton is a career metalworker who has worked at various job shops that produce parts for the consumer product development, laboratory equipment, medical services and custom machinery design industries. He has received six U.S. patents and lives in Alamo, Calif. Lipton’s column is adapted from information in his book “Metalworking Sink or Swim: Tips and Tricks for Machinists, Welders, and Fabricators,” published by Industrial Press Inc., New York. The publisher can be reached by calling (888) 528-7852 or visiting Industrial Press. By indicating the code CTE-2012 when ordering, CTE readers will receive a 20 percent discount off the book’s list price of $44.95.
    *This article is reprinted with permission from CUTTING TOOL ENGINEERING Magazine, and is protected under U.S. and international copyright laws. CUTTING TOOL ENGINEERING Magazine is protected under U.S. and international copyright laws. Before reproducing anything from this Web site, call the Copyright Clearance Center Inc. at (978) 750-8400.
    Nov 2007
    Houston, Texas
    22
    Thanks for those tips. I have a couple of questions, and I hope they don't sound too amateurish as I'm really only a hobbyist at best. I have always ground and used HSS blanks for use on my little S. Bend
    manual lathe. I have not purchased (yet) any tool holders where inserts are used....seems to make a lot of sense to use them. But if I were to want to run a final clean-up cut, say 2 or 3 thousandths, is a newly
    ground HSS bit sharper than a tool holder w/insert? (assuming all parameters such as position and bit geometry is correct).
    I was also taught to hone my bits before using on the lathe, but I'm not sure if it's really needed or if perhaps that's only if turning wood.
    Sorry for the questions from the "dark ages", and thanks for your response in advance.
    Sep 2013
    Woodstock NY USA
    74
    6
    14
    mcload, An indexable insert can be purchased with or without a honed edge so both can have a sharp cutting edge. All coated inserts have honed edges so the coating can flow around the edges. If I were you I would not invest in indexable tools as they are very expensive compared to hss or a brazed carbide tool. As long as the material is soft enough to cut with hss, I would use it. If I needed carbide I would purchase brazed tools because they can be sharpened many times and are cheaper than most inserts. The only drawback is the tools needed to sharpen them. To take a cut as light as you are suggesting to finish your parts, you need a sharp edge. Such a light cut is usually not recommended as it tends to burnish the edge depending on the material you are cutting. I only hone a tool when I am cutting steel. Hope this helps.
    Oct 2013
    111
    57
    58
    I respectfully disagree with hologrind on buying brazed carbide. Buy a GOOD Quality insert tool set and don't look back. I bought a rouse arno set and never regretted it, my boss / partner bought some Enco no name American insert tools and all have failed in that the 2-56 screws broke.
    Last brazed carbide I bought were all improperly sharpened and flat wouldn't work until resharpened, I trashed them. too much trash tooling out in the ether nowadays.
    Dec 2016
    122
    7
    Problem with brazed carbide is they are nearly always not ground to cut. They shape it to a standard shape and the shape it comes with will not cut no matter what, unless of course you buy expensive American or German made ones...
    Take those cheap brazed boring bars that usually comes with those Shars boring head for example... the head itself is ok, it works, albeit with some modification (better screws for example) but the bars flat out WILL NOT cut. The reason is because the carbide is way above centerline and as such it will barely cut out of the box. Once you grind it properly it cuts great. I did not know this until I watched a video from This Old Tony and before I was constantly cracking those boring bars and having it skip and chatter, thinking that it was my fault or something. I ground one in a diamond lapping wheel and it made a huge difference. It can take huge bites into 1018 steel and not chatter or break.
    If you got one of those diamond lapidary lapping machines (or have access to one, it helps to major in Geology) grind a better relief angle into those brazed carbide tools... I promise you it will cut 1000 times better!
    Only insert toolings cuts out of the box, even those Chinese inserts cuts better than brazed carbide without modification.
