Hi all,
Because of an oil leak in the knee of my "new" Abene mill I removed all oil out of it.
Then I found out there was no oil at all in the compartment for the vertical spindle.
Looking trough the oil plug hole with a small camera I saw grease on the spindle.
I just partially removed the outside cover of the spindle and indeed the spindle was full of grease.
I assume now that the oil seals between the telescopic cover-parts are leaking and that's why they used grease.
Any idea if this is simple to fix?
Or shall I also just grease this spindle once in a while, just like the last owner apparently did?
I couldn't find pictures of a dismantlement telescopic tube, but what I see in the parts-manual it are just o-rings, but those will damage on the damaged outsides of the steel tubes and start leaking again.
Any ideas?
Any ideas?
