Dear all please help on this.
I started making some T nuts on my ALG100 FP1 copy.
Straightforward job, started by side facing the 20mm (3/4") part. 1060 steel, nothing too hard.
Problem is that even at modest cuts, a couple of tenths of a millimeter I had a huge knocking/rattle sound from the vertical head.
I think it is very obvious in this video
vertical head rattle - YouTube
I, instantly took the front of the vertical head apart and examined the bevel gears, nothing seemed problematic. Tried again, same thing. If I tried higher speed and even lighter cut knocking reduced but the surface finish was just awful, a constant chatter (forgot to take a picture...).
Trying to identify the source of the rattle, I noticed that the keys had some play in the spindle's keyway. (that instantly reminded me of a similar post I had read here)
Play is as such:
key rattle 1 - YouTube
Took the vertical head apart and found out that the keys had some wear towards the spindle. Keyway seems relatively consistent in terms of width. Please have a look here:
key rattle 2 - YouTube
So, has anybody faced such horrible sounds? Do you have any suggestions on the possible root cause? Could it really be attributed to the key wear? I mean, there is a couple of gears in the drive train, I can't see why just a bit of play in the key would cause such an issue.
Would really appreciate any help on this.
BR,
Thanos
Play is as such:
BR,
Thanos
