dave111
- Nov 30, 2007
- Waterloo, ON, Canada
I can't really tell just yet how the ways are - Y axis slides very well. X and Z are a bit stiff. Someone covered the exposed ways with grease for protection I'm assuming. One of my main goals with disassembling this machine was to clean the oil passages, I pumped the way lube pump a couple times but didn't notice any difference in sliding so I think it needs a good cleaning.
If your machine has a lube pump then probably all is fine, that ensures that oil rather than grease goes to the slideways.
The backing/bearing plates are steel, and bear against cast-iron ways. The curious thing is that almost all of the wear takes place in the harder (steel) plates, because the cast-iron part acts like a lap to wear away the harder material. So this is not conclusive but very indicative
Cheers,
Bruce
Ross
I have taken apart some Deckel FP3`s And on at least the older ones,before 1979, I have never seen any turcite on them
Dan
The wierd thing is those dubble angle headed Deckels bring €2000,- less as one with a straight head
They are more noisy in general and also the spindles are not in the middle of the X-axe movement
The most wanted FP3 has a fixed table and a straight head
Peter from holland
The same pull-out style as my 69 FP2. I would think twice about moving the spring. The wheels spin faster than one expects under power feed and those springs stop them from impacting you. I find them a really nice feature and I expect you will when you tram your vise. Leaning to see a DTI or lifting the knee whilst under rapids (or even feed) could cost you your left nut without that spring.Ross - the handwheels are the pull out to engage style....I will be removing those pesky springs in the handwheels.
Notice
