Results 1 to 6 of 6
    Milacron's Avatar
    Milacron is offline Diamond
    Dec 2000
    Coastal Dogpatch, SC, USA
    41,120
    Default Deckel no. 40 test bar... value ?
    No. 40 with buttress threads, test bar portion about 11 inches long. Appears near pristine.... any idea what one would typically sell for on USA eBay and/or from Franz Singer ?
    sneebot is online now Hot Rolled
    May 2001
    Massachusetts
    660
    I believe they are priced on the Singer site? (they used to be). I sold one here through PM a few years back for $225.
    Milacron's Avatar
    Dec 2000
    41,120
    Quote Originally Posted by sneebot View Post
    Singer Werkzeugmaschinen GmbH
    He does show a "gauge arbor" for 195 Euro, but the test rod appears tapered.. (or is that just optical illusion ?), whereas mine is straight. Guessing that Singer's version is not official Deckel since it has the separate buttress stud.
    As an aside, interesting the "drive ring" is more expensive than the gauge arbor ! ...I think I have one of those lying around somewhere. I made one years ago, but pretty sure the one I have now is official Deckel.
    hudson-ch is offline Plastic
    Jan 2006
    Zurich, Switzerland
    38
    A better picture is on ebay:
    Prüfdorn SK40 S20x2 z.B. für Deckel Fräsmaschine | eBay
    I assume that Franz240455 is Singer, but I might be wrong. Further a tapered test rod would be completely useless, probably the picture was taken with a wide angle lens.
    In case of interest it would be better to clarify with the seller.
    Best regards,
    hudson-ch
    Milacron's Avatar
    Dec 2000
    41,120
    Quote Originally Posted by hudson-ch View Post
    Re the taper, yeah that didn't make any sense to me either but I thought maybe there was some secret use for a tapered one I'd never considered !
    Interesting that the price is considerably more on eBay than on his website.
    AlfaGTA is offline Diamond
    Dec 2002
    Benicia California USA
    5,223
    Test bar is a very useful tool...i have two, (one at home and one at work) genuine Deckel units. Very nicely made and accurate.
    The easiest way to get the dividing head in tram....Great for tramming in a vertical head where you can't use the table (such as setting up the spiral milling attachment....
    I also use mine as a dead accurate test bar when needing a true line between centers.(the centers are dead accurate with the OD) Great for checking tram / alignments on a lathe...
    Also use my test bars on my CNC's. Singer sell cute little adapter rings that thread onto the buttress thread and allow gripping by the power drawbars of the CNC's. (works with the standard manual threaded collets as well).
    Oh and it makes a swell standard for calibrating my Walter tool setter!
    Cheers Ross
