Motorfiets
- May 30, 2009
- The Netherlands
Hello,
After lunch my fp5 had shutdown and didn't respond anymore.
I powered down and repowered the machine ; noticed that the normal humming of pump wasn't there.
Looked in the power cabinet and status of sps was different then normal.
The code 1,2,3 and 4 led off in combination with led 5,6,7 and 8 on. (board on the left in the sps)
Looked up that code and the manual says something like 'no response' from the control unit.
Did a reset procedure on the control, that went well but after that two strange things :
- after setting the rs232 parameters , able to start downloading a program but after that finished the program list stayed empty.
Did several attempts but same result.
strangly the total available memory does go down.
- later also an sps error FP84 came up.
In 'not my' manual that points to a pallet error , but i don't gave that on the machine.
- On the left of the control the third led from the left is lit. Normally that was never the case if i remember correctly.
it's the /\/->| symbol , i'm not sure what it stands for.
p.s. the two attery voltages in the control are ok.
didn't check the one in the sps yet but age is the same as the others.
Anyone any idea what to look for ?
Gr.
Sander
Gr.
Sander
