T_Rex
- Jun 22, 2007
- South Africa
Hi There,
I have sorted the power to the machine...eventually
The problem that I get is weird.....when I reference the Z-Axis....no problem - the same goes for the Y-Axis.
Both these Axis's I can turn the feed pot to maximum....and the Axis's move with no problem.
When I move the X-Axis.....the control shows that it moves with the feed pot at virtually Zero. I have tried to watch the manual scale...and I cant see the movement.....as soon as I turn the pot up a teeny bit...the machine gives me a X-Axis movement detection error.
What could cause this....my machine has an Heidenhein TNC 310 controller on it.
I have also noticed that although the control says that the X-Axis is moving....I can't pick up any voltage on the X-Axis's transformer???....I have even tried to switch the 4th Axis control card with the X-Axis....still the same problem.
I really don't know what could be causing this.
The Machine has siemens control cards installed....looks pretty old ...and fuly DC.
Please help me....pretty please...I really need this machine to run now.
Kind Regards.
T_Rex
Kind Regards.
T_Rex
