Luke Rickert
Hot Rolled
- Oct 24, 2007
- OSLO
I need a good quality but not crazy expensive dovetail cutter for making some smallish parts in cast iron. (150mm/6 inch long 18mm deep dovetails) I don't want Chinese junk but the only only other thing I have found so far is a solid carbide cutter for something over 600USD equivalent. This is for running in my Schaubln 13 mill and cutting SG cast iron so I won't be hogging out material and will cut as much as possible with end mills etc before hand. The part is unfortunately not doable with a horizontal cutter given access issues so I need to use the vertical head. I wish I had a shaper or planer for this but I should be able to do it with the mill, it just requires the correct tooling.
I have seen some people making dovetail cutters with triangular carbide inserts which I could do if there is nothing else to be found. I could also braze carbide on a home made cutter and grind it to shape with my cutter grinder but I am not going to get more than one or two cutting edges if I go that route which seems like it will make for some slow cuts.
Any ideas or suggestions?I am only prototyping a couple of parts, so figure 8 cuts total. I just can't see Chinese HSS doing the job and don't know where to look for something else that makes sense for my application.
thanks
Luke
thanks
Luke
