Oerlikon Italiana Milling Machine size "3", Model MN3H - Page 7
Page 7 of 7 FirstFirst ... 567
Results 121 to 123 of 123
  1. #121
    Apr 2006
    Manchester, England
    6,736
    827
    3701
    That's a very well made machine. It reminds me of the Swiss machines I worked on- nothing left to chance in there. Just look at the lube pipe set up in that photo. Absolutely bullet proof design. That'll last forever. If Sachmanram is following this look at the beautiful examples of gear tooth edge rounding on those gears. Re The double sight glass arrangement - The lower sight glass is for the static oil level and the upper sight glass is to indicate the flow of oil from the lube pump to the gallery. I'm really impressed with the workmanship I can see, even the bracket that carries the oil pipes appears to be screwed and dowelled into position. Quality work.
    Regards Tyrone.
  2. Likes Sachmanram, texasgunsmith liked this post
  3. #122
    Apr 2013
    Damascus, MD
    1,027
    2871
    515
    Quote Originally Posted by texasgunsmith View Post
    There is some trace, fine metal in bottom of tower, much like you might find in a standard transmission, or rear differential of a vehicle, but nothing concerning, nor any big pieces. Just normal gear box accumulation. I'll get that cleaned out before filling oil.
    I would suggest sticking a few strong magnets in several places on the bottom, so that the fine metal particles do not recirculate.
    Paolo
  4. Likes texasgunsmith liked this post
  5. #123
    Feb 2016
    395
    164
    107
    Quote Originally Posted by Paolo_MD View Post
    Paolo
    I was thinking the same thing. I usually do that on big gear boxes, and trans.
