ome.machining
- Nov 7, 2015
- Denmark, Europe.
Hi all
I have a question, and I hope you have the answer to it [emoji16]
It's my 1962 prvomajska alg 100 mill, which I noticed have some movement in the horizontal spindle.
I've set up an dial indicator on the spindle nose, and put a chuck with a mt4 into the spindle. When I pull up/down, I get a 0.1mm reading, and if I push with full strenght I can move it 0.3mm.
This pull done 120mm from the spindle nose, on the chuck.
But, how much movement should be accepted?
And, I presume I can adjust the bearings into a more tight fit? This lead to the actual question.
Where do I adjust the slop in this bearing? I share some pictures [emoji846]
Hope you can help, best regards
