I was doing a boring operation that would take about 15 minutes to bore. About 8 hours into the part. 10 minutes in, I hear 'Wong Wong Wong' as it is cutting unevenly. Stop machine. See bore is not cutting on one side. Stop program and try to go to manual.
"Error: Unable to change mode. Origin Point Unknown" (or something close to that. I did not take a photo)
Remove part. Turn off machine, turn on. Can't get out of program mode. Turn off, go to manual mode, turn on. X axis origin point has been lost and shows up in red. The spindle had moved about 1" in the X during the period of time when trying to assess the damage. Re-home the X axis. Done. All that is lost is the part I was working on.
This is the first time I have done boring operations and I did a test first. Not as deep a bore, or one for as long a time frame of 15 per bore. I have never seen a time when I had to re-home an axis. As well, as this was boring, the machine was not moving in the X axis as it was to stay stationary.
My thoughts are:
1. Scales are dirty.
This is an old machine. Maybe somehow there was a bit of dirt that gave a bad signal to the encoder that could have caused this. Is this possible? Is there a way to clean the scales?
2. Boring head overloaded axis.
Looking at the part, I wonder if when I bored the hole with the end mill it taped the hole (3" deep 7075 aluminum, 4" diameter). This was my first pass and I was doing a 8 thou engagement. Towards the point of failure it was getting up to (my estimate) 20 thou engagement. I didn't expect a taper in the hole. The machine was running at 25rpm and 0.2ipm. That speed and feed produced a good finish on my test piece, but not so much on the finished part. I had setup to take off 100 thou diameter with the boring operations. This low rpm is hard on a motor and I wonder if the torque and force was too much, moving the axis without motor input and causing the control system to not understand what is going on.
3. Oil
This is an odd idea from my manager. The mill has an oil tank reservoir spyglass that shows the oil is near the lower end of the tank but still has some ways to go. The hydraulic motor had some issues in the past and the oil detection switch was wired stuck on as it would not pump even with oil present. As well, the hydraulic pump has 28Ω/28Ω/3.8Ω across the three phases as we measured it when we got a new relay to turn it on. The pump still works and still generates pressure. He considers this an important point to bring up, but I don't think the mill uses hydraulics in the X axis.
The mill is a Deckel FP50CC/T. Looking to see if anyone has had anything similar. Also, anyone know where I can find decent FS for boring 7075?
My thoughts are:
3. Oil
