Luke Rickert
Hot Rolled
- Oct 24, 2007
- OSLO
After some time of not using the high-speed head I have for my schaublin 13 due to a lack of collets (and having no idea what the collets are despite considerable research) I have started trying to make an adapter to use ER20 collets. This is for drilling with the quill and light milling only (max speed is a bit over 6k rpm)
I tried hard turning a cheap ER20 MT2 adapter to fit the taper but have run into some difficulties. My big lathe cuts the steel just fine and leaves a better finish than the original grinding and the fit seems ok with blue in the spindle but there is considerable runout when I test fit it. This could be how I held the part between centers using the mouth of the ER cavity and it is a cheap collet so that might be part of it but no matter what the location of the adapter doesn't seem quite secure as it depends on the unground bore to locate the end of the adapter.
here is what the current adapter looks like:
Shared album - Luke Rickert - Google Photos
The plan was to use the threads on the spindle nose and a special nut with pins and a slot to hold the adapter into the spindle if that makes any sense.
here is a sketch:
The rough parts of the bore are not that rough in reality but are not ground like the area near the end. The contact angle is 15 degrees as far as I can tell but as I have said I haven't found a spec anywhere.
It seems like I need to make something that can be more or less permanently attached into the current bore and then the ER20 cavity turned into the end to ensure concentricity.
I am not sure if there is enough material to grind the spindle out to an ER20 cavity which is too bad as the M25x1,5 thread would allow the use of off the self ER20 nuts. I could perhaps make an adapter and special nut to use ER16 which would fit within the current bore and is big enough for the purposes of this head.
I suppose what I should do is disassemble the head and remove the spindle. I am not crazy about taking it apart but it seems like the most logical way to proceed as any workable solution is going to end up with the spindle on the lathe.
I could attach something into the bore and then true it on the mill using a cutter held on the table but I would not be able thread etc so it would have to be a two part (glued) solution.
Any thoughts?
Luke
here is a sketch:
Any thoughts?
Luke
