Stan Krum
- Feb 24, 2007
- Central California, USA
I have read on Tony's UK website that the deckel HS milling head has a morse taper 4 spindle, just like the regular FP1 mill head (yes, unless its the newer MK4??). Now my regular head has the adapter installed so I can use the deckel 20mm dia collets -or- I can remove the adapter for Mt#4.
I looked carefully at the HS head today, and it takes the deckel 16mm dia collers, I believe the same as the grinder collets. It does not seen to be an adapter, at least it's not readily apparent to me. My FP1 is early 50's vintage, but the hs head is a later acquisition from ebay - do not know the year it was made. So, were there 16mm collet spindles made? Or is it that I did not look close enough? I searched the archives, and the question has been raised - but was not answered. Thanks. Stan
